DuoRoller Brush
VibraRise® Mopping System
Auto Mop Washing
Auto Mop Drying
Auto Tank Refilling
DuoRoller Riser® Brush
VibraRise® 2.0 Mopping System
Forget about cleaning, including robot maintenance. With Roborock’s all-in-one docking system – RockDock® Ultra, and the most advanced cleaning technologies – DuoRoller Riser® Brush and VibraRise® 2.0 Mopping System, S8 Pro Ultra is here to free your time.
Available in Black and White
Washes robot mop automatically during cleanup and when finished so you don’t have to after each use.
Safely dries the washed mop and bottom of the dock with warm air, preventing mold growth and unpleasant odors even in wet weather.
Automatically empties dust and dirt after each cleanup, allowing for up to 7 weeks1 without changing a dust bag. What’s more, the dual brushes clean themselves as well.
Refills the robot water tank during cleanup for a maximum mopping range of over 300sqm (3230sqft)2.
Free your time with the self-cleaning design that cleans the bottom of the dock for easier maintenance.
Make your home cleaner than ever before with the new two-fold brush and mopping system, featuring the DuoRoller Riser® brush and VibraRise® 2.0 mopping system.
HyperForce® suction has been improved to 6,000 Pa3, this means your robot vacuum can reach deeper and capture debris and dust from hard floors and carpets.
Carpet cleaning is a breeze with Roborock Carpet Boost+ system® that’ll leave your carpet mess-free from pet hair to bread crumbs.
30%
See how Roborock Carpet Boost+ system® works
The mop lifts5 automatically, ensuring it does not touch the carpet6 when vacuuming.
DuoRoller Riser® brush and increased suction power help remove mess from carpets more effectively, enabling a thorough and deep cleaning experience by cleaning the carpets twice7.
The VibraRise® 2.0 has improved its vibration modules two-fold, meaning that the cleaning zone is widened. Paired with high-speed scrubbing and consistent pressure on the floor, the mop can clean anything and everything, from soda to dried-on spills, effortlessly.
2x
Vibration Modules
3000 times/min
High-speed Scrubbing9
> 6N
Mop Pressure10
5mm
Mop Lifting5
For different cleaning tasks, the brush and mop can be lifted automatically to maximize the cleaning effectiveness and also avoid leaving stains after a clean.
Vacuum-only | Mop-only | Carpet cleaning | Returning to dock | Mop drying | |
Brush lifted | |||||
Mop lifted |
Brush lifted | Mop lifted | |
Vacuum-only | ||
Mop-only | ||
Carpet cleaning | ||
Returning to dock | ||
Mop drying |
Need to clean while you rest? Your robot vacuum can minimize cleaning noise when it’s mopping12, allowing you to catch up on some much-needed rest anytime.
With 3D structured light and infrared imaging technology, the Reactive 3D Obstacle Avoidance system can help the robot vacuum identify and avoid potential hazards on the floors, in both bright and dark rooms, bringing you a worry-free cleaning experience.
Objects13
Pedestal
Footwear
Pet Waste
Fabric
Power Strip
Wire
Dustpan
Obstacle
Scale
PreciSense® LiDAR Navigation
Customizable App
Features
Total Control Is a Tap Away
Fast Charging
Off Peak Charging Supported
S8 | S8+ | S8 Pro Ultra |
Auto Mop Washing |
Auto Mop Drying |
Auto Tank Refilling |
Auto Dust Emptying |
DuoRoller™ Brush |
DuoRoller™ Brush |
DuoRoller Riser® Brush |
VibraRise® Mopping System |
VibraRise® 2.0 Mopping System |
Reactive 3D Obstacle Avoidance |
S8 vs S8+ vs S8 Pro Ultra
DuoRoller™ Brush
DuoRoller™ Brush
Auto Mop Washing
Auto Mop Drying
Auto Tank Refilling
1. Actual emptying interval will depend on use habits and environmental factors.
2. Based on internal testing carried out on hard floors with a full clean water tank in the S8 Pro Ultra’s dock using default mode. Actual results may vary, depending on room characteristics.
3. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2016 / 5.8 standards, using Max+ mode with a full battery. Actual results may vary according to the home environment.
4. Compared to Roborock S7. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
5. Based on internal testing carried out by the manufacturer, the mop module can be lifted up to 5mm.
6. Automatic mop lifting is only suitable for low-pile carpets not higher than 4mm. Alternatively, you can select avoid mode on the carpet settings in the Roborock and Mi Home App.
7. To clean the carpet twice, select deep mode on the carpet settings in the Roborock and Mi Home App.
8. Compared to Roborock S7. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
9. Based on internal testing carried out by the manufacturer. The term relates to the integrated mop module being able to be driven to produce high-speed reciprocating vibration of up to 3000 times/min, i.e. up to a frequency of 50Hz which is within a “sonic” range (20 to 20,000Hz).
11. To vacuum first and mop later, select WashVac routine in the Roborock App.
12. Tested on mop-only mode with mild scrub intensity and deep+ mop route. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
13. Based on internal testing carried out by the manufacturer, S8 Pro Ultra can see and bypass objects down to as small as 5cm wide, and 3cm tall. Recognition accuracy may vary depending on environmental factors.
14. Compared to Clean&Mapping mode. Actual results may vary according to the home environment.
15. Compared to standard cleaning route mode. Actual results may vary according to the home environment.
16. Compared to Roborock S7. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
Get updates on our latest news, special offers and more.
you have successfully subscribed!
