Qrevo Edge 2 Pro
The Sharp Choice.
Buy Now
Find the Right Model for You
From carpets to corners, experience truly powerful, adaptive cleaning with the Qrevo Edge 2 Pro—seamlessly paired with an advanced multifunctional dock that keeps your floors hygienic, your hands free, and your home healthier for the whole family.
Industry-First¹ AdaptiLift™ Chassis
Engineered for Redefined Dynamic Carpet Cleaning.
Outstanding Cleaning Power
25,000 Pa HyperForce® Suction² & 12N Dual-Spinning Mop System³
Dual Anti-Tangle System
Tangle-Free Cleaning, Always.
Automatic Mop Detachment
Mop detaches automatically to protect carpets from moisture.
7.98 cm Ultra-Slim Design
Cleans under low furniture with effortless ease.
Hygienic Multifunctional Dock
100°C Hot Water⁴ Mop Washing and Auto Detergent Dispenser for a deeper clean.
From Carpets to Corners:
Deep Cleaning, Redefined
Enhanced AdaptiLift™ Chassis
Climbs, Lifts, and Cleans Like No Other
30% Higher⁶
Dust Pick-Up Rate on Long-Pile Carpets
Industry-First Dynamic Cleaning⁵ for Up to 3cm Carpets
Experience industry-first dynamic chassis elevation with omni-directional wheels. The robot intelligently adjusts the body height to maintain optimal suction contact on carpets up to 3cm.* This ensures deep, consistent cleaning on carpets up to 3 cm of varying pile heights—finally delivering on the promise of real carpet cleaning performance.
4cm¹ Maximum Double-Layer Thresholds Crossing
Prevent Getting Stuck
Next-Level Suction for
Ground-In Dirt
Ground-In Dirt
Next-Level Suction for Ground-In Dirt
Conquer every surface with confidence. Boasting 25,000 Pa of ultra-strong suction—among the highest in its class⁷—it effortlessly lifts embedded dust and debris, even from dense, high-pile rugs.
0 25,000 0 Pa
Max Suction Power²
Want to deep clean carpets or avoid them entirely? One tap is all it takes. Your robot adapts: stronger suction when cleaning carpets with the mop lifted, or precise edge-cleaning to skip rugs and keep them dry*. You’re in control of every room, every rug, every time.
*These carpet cleaning settings need to be manually enabled and selected in the Roborock app.
Upgraded Mopping Performance
Flawless Finishes,
Every Time
Flawless Finishes,
Every Time
Flawless Finishes,
Every Time
200 RPM
Spinning Speeds⁸
12N
Max Downward Mopping Pressure³
Scrub away tough stains with dual rotating mops that apply up to 12N of downward pressure and warm water.
Transition seamlessly from hard floors to carpets with an auto-detaching mop. When vacuum-only or carpet-first modes are enabled, the mop is intelligently detached, avoiding moisture transfer and keeping carpets dry, fluffy, and fresh.
Liftable Brush and Mops
Vacuum Only
Mops detached
Main brush lowered
Mop Mode
Main brush lifted
Clean Carpet
Clean Carpet First
Usual Cleaning Path
Mop detached
Chassis lifted
Mop lifted
No More Hair Hassles
Long hair? No problem. The DuoDivide® Main Brush and FlexiArm Arc Side Brush work together to actively reduce hair entanglement—even with strands up to 40cm long. Just enjoy seamless vacuuming from start to finish.
DuoDivide®
Main Brush
Hair Tangling Rate⁹
Hair Removal Rate¹⁰
FlexiArm
Arc Side Brush
Hair Tangling Rate¹¹
FlexiArm Technology
Corners, Cracks, and Edges—Covered
Roborock's exclusive FlexiArm Arc Side Brush and Edge Mopping System reaches into hard-to-clean crevices and along walls, delivering unmatched edge-to-edge performance and full perimeter coverage.
Edge and Corner Coverage¹²
0mm
Along the Edge and Corner¹²
It Cleans. Then It Cleans Itself.
It Cleans.
Multifunctional Dock 3.0 Hygiene+
100°C Hot-Water
Mop Washing
100°C Hot-Water Mop Washing
Up to 100℃⁴
Bacteria Removal Rate¹³
Using up to 100°C hot water⁴ , our Multifunctional Dock 3.0 Hygiene+ helps loosen stubborn dirt, food residue, and greasy stains from the mop pads. With every wash, mops are refreshed more effectively—supporting a more thorough and hygienic floor clean.
Dust Bag Fresh-Air Drying
Ambient airflow helps dry residual moisture in the dust bag, reducing odors and keeping the dock fresh.
The dock base stays hygienic with up to 100°C⁴ hot water and the self-cleaning module, reducing manual maintenance.
55°C Warm Air Drying
Dries the mops and dock base thoroughly with 55°C¹⁴ of warm air, preventing the growth of mold and unpleasant odors.
Warm Water Auto-Refilling
Equipped with an auto detergent dispenser, the dock automatically adds cleaning solution for a more thorough and effortless mop cleaning
Allows for up to 65 days¹⁵ without manual emptying.
Detachable Dock Base
Whole-Home Wellness,
From Start to Finish.
Every clean, every cycle—designed for sensitive users and healthier homes. Certified¹⁶ for allergy care, infants, and furry family members.
Smarter Sight, Slimmer Fit
Smarter Sight,
Slimmer Fit
Reach Where Others Can’t¹⁷
At just 7.98 cm tall, this is one of the slimmest¹⁷ Roborock equipped with a full LiDAR system. The retractable LDS allows it to glide effortlessly under low furniture, reaching places other vacuums can’t—and leaving no dust behind.
100% Success Rate
Cleaning in Spaces ≥7.98cm High¹⁸
Rise, Retract, Navigate Anywhere
In Open Spaces:
Under Furniture:
In Open Spaces:
Under Furniture:
Precision Sensors, Reliable Design.
Upward Range Finder:
Measures overhead clearance for automatic LDS adjustments.
Top Contact Sensor:
Detects overhead obstacles, preventing bumps and scratches.
Cycle-Tested Durability: LDS mechanism validated through 10,000+ lift-and-retract cycles for long-term reliability.¹⁹
10,000+
Cycles
Knows What’s Ahead
—And What’s Beside.
Accurate Object Recognition, Day or Night
Types of Objects Recognized²⁰
Ensures Accurate Edge Detection
The VertiBeam™ lateral laser system precisely measures the distance to side obstacles, enabling accurate edge cleaning along furniture and surrounding objects.
Tap, Tap, Clean
  • Automatically performs a vacuum-then-mop routine in rooms left uncleaned for over 30 days.
  • Automatically deep cleans rooms that have not been cleaned for a long time
  • Lowers power and reduces noise during Do-Not-Disturb periods
  • Re-washes the mops right after cleaning kitchens and bathrooms or after a second mopping pass
Roborock SmartPlan® 3.0
One Tap to AI-Driven Cleaning
From recognizing room types to tracking usage habits, Roborock SmartPlan® 3.0 tailors every session—boosting suction when needed, and rewashing when it matters. Smarter cleaning, all with just one tap.
Pet-Friendly Intelligence
Closer to Your Furry Friends
Video Call
Pet Snaps
Automatic Pet Recognition
When approaching kittens or puppies, the robot immediately stops its main brush and moves aside to avoid startling your beloved pets.
Search for Your Pet
Say “Hello Rocky” for Help
  • "Clean here"
  • "Just vacuum"
  • "Clean the kitchen"
Matter Protocol
Embrace the Future
of Smart Living
Works Great with
Third-Party Voice Control
Fully charged
After Meals
Launcher Widgets
Apple Watch App
Specs
Qrevo Edge 2 Pro
Qrevo Edge 2 Pro
Qrevo Edge 2 Pro
350*352*79.8mm
381*475*488mm
1. Roborock was the first in the robot vacuum industry to mass produce a product featuring a liftable chassis system with three-wheel control, officially launching this technology in Q3 2024. Its threshold-crossing capability is based on internal testing carried out by the manufacturer. This product is tested to cross thresholds up to 4cm, including a 3cm threshold plus an additional 1cm track on top for double-layer thresholds, or up to 3cm for single-layer threshoblds. Actual results may vary depending on environmental factors.
2. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
3. Based on internal testing conducted by the manufacturer. The maximum downward mopping pressure is achieved when the “Deep Cleaning for Heavy Dirt or Stains” function is manually enabled in the Roborock app. Actual results may vary depending on environmental conditions.
4. Based on internal testing conducted by the manufacturer. The water at the clean water dispensers of the base can be heated up to 100°C (212°F) under standard atmospheric pressure (1 atm, 101.3 kPa) at room temperature. Actual temperatures may vary depending on environmental conditions such as altitude and atmospheric pressure.
5. This feature is powered by Roborock’s AdaptiLift™ Chassis—the industry’s first mass-produced liftable chassis system with three-wheel control, launched in Q3 2024. The dynamic carpet cleaning capability was officially introduced in Q3 2025.
6. Based on Roborock internal testing using Max+ mode. Compared to the performance on the 2cm long-pile carpets of previous Roborock vacuum robots. Actual results may vary according to the home environment.
7. Based on research conducted by Roborock as of November 2025, Qrevo Edge 2 Pro delivers one of the highest suction power within the Qrevo Edge series.
8. Based on internal testing carried out by the manufacturer, when selecting extreme water flow in custom mode, the mops can spin at a maximum speed of 200 rpm. Actual results may vary depending on environmental factors.
9. Certified No.PT/25/GEN/0342 by SGS. Actual results may vary according to the home environment.
10. Certified No.PT/25/GEN/0341 by SGS. Actual results may vary according to the home environment.
11. Certified No.PT/25/GEN/0340 SGS. Actual results may vary according to the home environment.
12. Based on internal testing conducted by the manufacturer using side brush for edge and inside-corner sweeping performance. Actual coverage and distance may vary depending on the home environment.
13. Based on testing carried out by TÜV Rheinland on Escherichia coli under default self-cleaning mode, over 99.99% of bacteria on the spinning mops are effectively removed. Certification ID: 0000088785. Actual results may vary according to the home environment.
14. Based on internal testing carried out by the manufacturer, the air at the base’s outlet during drying can be heated up to 55°C under standard room temperature. Actual temperatures may vary due to environmental factors.
15. Based on internal testing carried out by the manufacturer. Actual emptying intervals will depend on usage habits and environmental factors.
16. Based on testing carried out and certified by SGS and TÜV SÜD. Actual results may vary depending on the home environment. Certification ID: No.PT/25/GEN/0370, No.Z2GCN1238210008, No.Z2GCN123820009.
17. Based on research conducted by Roborock, as of November 2025, the Qrevo Edge 2 Pro is the thinnest model among Roborock's vacuum robots.
18. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
19. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
20. Based on internal testing carried out by the manufacturer, the robot vacuum can see and bypass objects down to as small as 5cm wide and 3cm tall. Recognition accuracy may vary depending on environmental factors.
