FlexiArm Design™ Side Brush
DuoRoller Riser® Brush
Hot Water Mop Washing
Intelligent Dirt Detection
Dock Self-Cleaning
Intelligent Voice Assistant
10,000 Pa HyperForce® Suction
Auto Brush and Mop Lifting
Single All-Rubber Brush
7,000 Pa HyperForce® Suction
Auto Mop Lifting
| Vacuum-only | Mop-only | Carpet cleaning | Returning to dock | Mop drying | |
| Mops Lifted |
| Brush Lifted |
| Mops Lifted | Brush Lifted | |
| Vacuum-only |
| Mop-only |
| Carpet cleaning |
| Returning to dock |
| Mop drying |
350 * 353 * 103 mm
340 * 487 * 521 mm
1. Certified No.1111280914 by TÜV Rheinland. Actual coverage and distance may vary according to the home environment.
4. Based on internal testing carried out by the manufacturer, when selecting extreme water flow in custom mode, the mops can spin at a maximum speed of 200 rpm.
5. Based on internal testing carried out by the manufacturer, the mop modules can be lifted up to 10mm.
6. Based on testing carried out by TÜV Rheinland on Staphylococcus aureus and Escherichia coli under default self-cleaning mode, over 99.7% of bacteria on the spinning mops are effectively removed. Test Report number: 244555550b1 002. Actual results may vary according to the home environment.
8. Based on internal testing carried out by the manufacturer, the robot vacuum can see and bypass objects down to as small as 5cm wide, and 3cm tall. Recognition accuracy may vary depending on environmental factors.
