4200 Pa Suction Power
Auto Dust Emptying Dock
300g Consistent Mop Pressure
PreciSense® Precision LiDAR
3D Mapping
Custom Cleaning Routines
3D Mapping
Roborock Q7 Max+ combines a wide range of effective robot vacuum technologies proven in generation after generation of Roborock vacuum. It delivers uncompromising vacuuming effectiveness, incredible ease of use, and the absolute convenience of the Auto-Empty Dock Pure.
Drag away dirt hiding in your carpets and lift off debris hiding in floorboard cracks with a maximum suction power of 42001 Pa.
A long-lasting all-rubber brush powerfully agitates carpets to release more dirt, flicks dust into the vacuum stream, and strongly resists hair tangles. Able to move across multiple panes, it keeps close to the ground for more effective cleaning.
Without Emptying
2.5L
7 Weeks
Clean often, empty rarely with the Auto-Empty Dock Pure. It empties your robot automatically into its 2.5 L dustbag, every clean, for up to 7 weeks2. When the bag is full, it can be swapped out in seconds. The dustbag is also an effective air filter, tested to filter 99. 7% of pollen as small as 0.3 microns3 , helping your air clean.
Dustbag
Without Emptying
Vacuum and mop simultaneously to capture fine dirt that vacuuming alone might miss. Equipped with an electronic pump, the Q7 Max+ offers 30 water flow levels so you can fine-tune cleaning to match your floor types and preferences.
240 sqm
300 g
Electronic Mopping
240sqm
Maximum Mopping Range4
300gConsistent Mop Pressure
Electronic Mopping30 Water Flow Levels
Combining the dustbin and the water tank into one unit increases the capacity of both. It also makes it easier to empty the bin and refill the tank in one trip.
470 ml
350 ml
Driven by a large 5200mAh Li-ion powerhouse, Q7 Max+ can clean non-stop for up to 3 hours5 on a single charge. Easily enough range to tackle most homes.
300 sqm
470 ml
Dustbin Capacity
350 ml
Water Tank Capacity
300 sqm
Maximum Vacuuming Area5
Roborock's PreciSense® LiDAR system is the brains behind your robot's extraordinary ability to find the most efficient way to clean throughout your home. The maps it creates power a suite of features controlled in the Roborock app.
Take control of your robot, start cleanups, send it to tackle specific rooms, and more with just the power of your voice. Amazon Alexa, Google Home, and Apple Siri Shortcuts are supported.
Curious kids and clumsy pets might accidentally start a clean with the push of a button. Stop that from happening with the Child Lock.
Have confidence that your Q7 Max can wander safely around your home. The Sensient® sensor array includes a suite of sensors, including cliff sensors, accelerometers, bumpers, and more. It will avoid rolling off of steps, getting trapped, or slamming into your walls.
Q7 Max+ |
Q7 Max |
Auto Dust Emptying |
4200 Pa Suction Power |
300g Consistent Mop Pressure |
PreciSense® Precision LiDAR |
3D Mapping |
3D Mapping |
Custom Cleaning Routines |
Q7 Max+ vs Q7 Max
Q7 Max+
Q7 Max
3D Mapping
3D Mapping
1. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2016 / 5.8 standards, using Max+ mode with a full battery.
2. Actual emptying interval will depend on use habits and environmental factors.
3. Based on testing carried out by an independent lab according to ISO/TS 11155-1-2001 and PT-22-000-100650 standards.
4. Based on internal testing carried out on hard floors with a full water tank, full battery, and low water flow. Actual results may vary, depending on the room characteristics. Range is an estimate based on the assumption that 20% of the area is covered by furniture and will not need to be mopped.
