            DYAD PRO
The Dyad Pro brings you the perfect clean, every time. Clean up wet and dry messes in an instant, and experience an entirely new level of cleaning with almost zero maintenance.
                DyadPower
DyadPower uses multi-rollers that rotate in opposite directions to ensure that no dirt is left behind.
Featuring the DyadPower cleaning head with 17,000 Pa1 of suction power, wet and dry messes simply have nowhere to go.
                Potted Soil
Tomato sauce
Coffee
Milk
Pet food
Eggs
And many other things
Make mess disappear, wet and dry, with the DyadPower cleaning head. With unbelievable suction power and
improved rollers, all mess is picked up, leaving behind the cleanest floor.
It provides cleaning on both sides thanks to a full-length roller and two front rollers sweeping up messes with margins of less than 1mm2.
Edge
Edge
1mm
1mm
                  Self-cleaning
Automatically transform your rollers from dirty to clean in an instant, without lifting a finger. Any mess made by your dog doesn’t stand a chance with more than 99%3 of dirt being removed from the rollers, thanks to its alternating scrubbing.
                Self-drying
Rollers are dried automatically with hot air, which means there won’t be any lingering odors. With noiseless drying mode, the only thing you’ll be hearing is your cat purring.
                    The Dyad Pro automatically adjusts its cleaning power and water flow for the perfect clean when detecting how dirty the floor is. The on-screen LED indicator tells you where the dirt is so you know where to focus.
                  Cleaning Made Smarter
with DirTec® Smart Sensor
                The Dyad Pro uses a cleaning solution dispenser that automatically adjusts depending on floor stains, to give you a perfect clean. 1 small cartridge of cleaning solution supports up to 20 tanks of clean water, lasting up to 600 minutes4.
Water Cleaning Volume
Auto Dispenser Duration
                The Dyad Pro easily connects to the Roborock App for your convenience. Need to use the Self-Cleaning & Drying System? Need to change the cleaning mode? These options (and more) are a tap away.
                The Dyad Pro uses its battery at a 30% higher efficiency when compared to the Dyad. With such industry-leading battery efficiency, it also allows you to deep clean your entire floor, providing a maximum cleaning range of up to 300 sqm4, on a single charge.
Clean Tank Size
Dirty Tank Size
Battery Life
Cleaning Range
Higher Battery Efficiency
                  The rollers rotate bi-directionally to help you easily move the Dyad Pro. At just 4.8kg you can pull and push effortlessly, all while playing around with your pet friends as you clean.
Lightweight Design
Dyad Pro vs Dyad
2. Based on internal testing carried out by the manufacturer, rollers approched 1 mm to edges of walls.
3. According to Roborock's internal experiments conducted with dirt and cat hairs.
4. Based on internal testing using ECO mode. Actual results may vary depending on environmental factors.
