| Brush Lifted | Mops Lifted | |
| Vacuum-only | ![]() |
| Mop-only | ![]() |
| Carpet Cleaning | ![]() |
| Returning to Dock | ![]() |
| Mop Drying | ![]() |
7. Based on internal testing carried out by the manufacturer, Roborock Qrevo MaxV can see and bypass objects down to as small as 5cm wide, and 3cm tall. Recognition accuracy may vary depending on environmental factors.
8. Compared to Clean&Mapping mode. Actual results may vary according to the home environment.
9. Up to four floors supported.
** During a transitional period, Roborock Qrevo MaxV may be depicted as Roborock Roborock Qrevo MaxV in certain channels.
