Saros 10R
Beyond Slim. Beyond Powerful.
Saros 10R Saros 10R Saros 10R
We’ve slimmed down the design to free up your life with Saros 10R. With the groundbreaking StarSight™ Autonomous System 2.0, it navigates complex environments effortlessly and recognizes obstacles with unparalleled precision. Enjoy smarter cleaning with its liftable chassis, main brush, mops, and side brush. Frequent maintenance is a thing of the past, thanks to the dual anti-tangle system and 10-in-1 multifunctional dock.
Saros 10R
7.98cm Ultra-Thin Design
As the slimmest Roborock ever1, it is crafted to navigate hard-to-reach areas easily.
Saros 10R
StarSight™
The industry-first StarSight™ Autonomous System 2.0 elevates navigation and obstacle recognition to a new level2.
Saros 10R
Dual Anti-Tangle System
Ensures 0% hair tangling rate with the DuoDivide® main brush and anti-tangle side brush.
Saros 10R
20,000 Pa HyperForce® Suction
Experience unparalleled cleaning performance with industry-leading 20,000 Pa suction power.
Saros 10R
Industry-First
AdaptiLift™ Chassis
Achieves up to 4cm threshold crossing and expands cleaning coverage thanks to the liftable chassis.
Saros 10R
FlexiArm
Riser
Technology
The extendable side brush and mop guarantee thorough cleaning around corners and edges.
Saros 10R
10-in-1
Multifunctional
Dock 4.0
Beyond maintenance-free, the upgraded dock offers auto mop removal for improved adaptability, and 2.5 hours of fast charging to save you time.
Saros 10R
Intelligent Voice
and App Control
Explore more using the built-in Intelligent Voice Assistant, Matter protocol, and the Roborock App.
Saros 10R with Refill and Drainage System
Drainage System
Truly Hands-Free Convenience
Expanding on the maintenance-free docking capabilities of the Saros 10R, a new variant featuring refill and drainage functions has been unveiled, taking hands-free cleaning to new heights.
Saros 10R
Auto Water Refill and Drain
Auto Water Refill
and Drain
The dock automatically refills the clean water and empties the used water. No more manual refilling or draining – just peace of mind after every clean.
Saros 10R
Check Your Environment
Drainage System
Please confirm the dock position and water pipe connections in advance to ensure compliance with the following installation requirements.
Clean Water Inlet
Power Plug
Dirty Water Outlet
More than 120cm
5
More than 30.5cm
6
More than 40cm
Saros 10R
This is image
This is image
Strong Wi-Fi coverage
This is image
Installation Requirements
1.
Maintain a space of approximately 30.5cm in height, 40cm in width, and 120cm in depth.
2.
Position the dock on a hard and even floor (wood, tile, concrete, etc.), flush against a wall. Avoid placing it on soft surfaces (carpet, mat, etc.) and in narrow areas.
3.
Ensure that the location has a strong Wi-Fi signal for an optimal experience with the mobile app.
4.
The height difference at any point on the drainage pipeline from the ground is recommended not to exceed 50cm.
5.
The installation distance for the water refill and outlet pipes is recommended within 6 meters. If this is not possible, please contact customer service for consultation.
6.
The water pressure range is 0.1-0.4MPa. If it exceeds 0.4MPa, please use a pressure-reducing valve.
7.
The pipeline layout should avoid passing through room doorways to prevent accidental breakage due to household traffic.
8.
Ensure there are no thresholds, tracks, or steps higher than 2cm between the dock's installation site and the cleaning area to avoid the risk of getting stuck or missed cleaning.
9.
Before installation, please disconnect the power supply of the dock. Turn off the main water supply switch, faucet switch, or angle valve switch in the house. Drain any remaining water from the pipes, and ensure they are connected without leakage before powering on.
Saros 10R
Compact Design
Save space with a sleek dock design that stands just 30cm tall.
*Products with a Refill and Drainage System are only available in certain regions and countries.
The Thinnest Roborock Ever
The Thinnest
Roborock Ever
Thanks to the next-gen StarSight™ Autonomous System 2.0, the Saros 10R is incredibly smart and impressively slim, effortlessly navigating under sofas and beds with advanced locating and mapping capabilities.
Saros 10R
Embrace the Future of
System 2.0
Embrace the
Future of
System 2.0
VertiBeam™ Lateral
Obstacle Avoidance
Superior Detection,
Seamless Maneuvering
Utilizing advanced lateral obstacle avoidance technology, it glides effortlessly around irregular furniture and walls, ensuring a thorough clean even around unfolded cables. Enjoy a hassle-free cleaning experience that adapts to your home.
roborock saros 10r VertiBeam™ Lateral Obstacle Avoidance
Unfolded Cables
Irregular Walls and Furniture
Break the Mold, From 2D to 3D
Break the
Mold, From
2D to 3D
Industry-First Dual Transmitter Solid-State LiDAR2
Industry-First Dual
Transmitter
Solid-State LiDAR2
A New Era of 3D Navigation
Unlike 2D sensing in standard LDS, the groundbreaking 3D Time-of-Flight (ToF) system achieves 3D scanning of your surroundings for precise navigation and flawless mapping. With face-recognition-level precision, it smoothly navigates tricky spaces like suspended cabinets, eliminating cleaning challenges like never before.
21x
Improved Sampling Frequency than LDS3
Enhanced Precision
It captures detailed depth and height information, accurately locating and mapping in challenging environments.
Comprehensive Capabilities
The robot seamlessly navigates your home while simultaneously detecting low-lying obstacles.
Improved Coverage
The sleek design allows the robot to access previously hard-to-reach areas, for improved cleaning coverage.
Advanced Obstacle Recognition
Smarter for An
Uninterrupted Clean
Featuring cutting-edge 3D sensors that accurately outline obstacles and an RGB camera for visual recognition, the Saros 10R adeptly navigates around unforeseen barriers and small objects. It glides smoothly through your space, ensuring a hassle-free routine.
*The Saros 10R uses a QVGA ToF sensor with 21,600 sensor points.
>21,600
Sensor Points*
108
Types of Objects Recognizable4
Cables
Small Objects
Unexpected Objects
Mirrors
Precise at Night
roborock australia saros 10r wire obstacle recognition
(Wire)
roborock australia saros 10r small object recognition
(Obstacle)
roborock australia saros 10r pet recognition
(Pet)
roborock australia saros 10r mirror obstacle recognition
(Mirror)
roborock australia saros 10r 3d sensors for precise recognition at night
Cables
(Wire)
Small Objects
(Obstacle)
Unexpected Objects
(Pet)
Mirrors
(Mirror)
Precise at Night
Saros 10R
Saros 10R
Privacy First, Always
Focusing on privacy and security, the Saros 10R ensures no images are stored. It boasts TÜV Rheinland certification as a secure smart home product and complies with ETSI EN 303 645 cybersecurity standards.
Zero Tangle, Guaranteed
DuoDivide® Main Brush
It prevents tangles and clogging with two parallel short bristle rollers and spiral blades that expertly funnel hair toward the central dustbin inlet, guaranteeing a pristine floor.
Hair Tangling Rate5
Hair Removal Rate6
Hair Tangling Rate5
Hair Removal Rate6
FlexiArm Riser Side Brush
FlexiArm Riser
Side Brush
The innovative arc-shaped asymmetric brush utilizes centrifugal force to prevent hair from tangling. It effortlessly directs hair to the bristle ends and cleans it up with ease.
Hair Tangling Rate7
Hair Tangling Rate7
Easy-to-Maintain Omni-Wheel
Easy-to-Maintain
Omni-Wheel
Industry-Leading
HyperForce® Suction
Pure Power,
Unmatched Clean
HyperForce® suction vanishes dust and dirt on different types of floors and carpets, ensuring that even the smallest particles are whisked away without a trace.
roborock saraos 10r HyperForce® Suction
Clean Closer, and Closer
Clean Closer,
and Closer
Edge and
Corner Coverage8
0mm
Along the Edge
and Corner8
Saros 10R
Industry-First AdaptiLift™ Chassis9
Industry-First
Expands Your Robot’s Reach
Expands Your
Robot’s Reach
Enhance your cleaning with the AdaptiLift™ Chassis, featuring independently adjustable three-wheel control for versatile lifting. Elevate the entire chassis or independently adjust the front, rear, left, or right halves to conquer complex home environments, ensuring optimal cleaning coverage.
4cm Maximum
Double-Layer Thresholds10
Mid-to-High-Pile
Carpets
U-Shaped
Furniture Leg
4x Liftable Designs
Tailored Solutions
for Every Task
Tailored Solutions
for Every Task
Designed to meet your home’s unique needs, the liftable chassis, main brush, side brush, and mops work together to provide automated and adaptive cleaning tailored to various scenarios.
Chassis & Mops Lifted
Mops Lifted
Main Brush Lifted
Side Brush Lifted
22mm Maximum Mop Lifting11 10mm Chassis Lifting12
Quick
Mapping
Vacuum-
Only
Mop-
Only
Carpet
Cleaning
Crossing
Thresholds
Returning
to Dock
Mop
Drying
Chassis
Lifted
Mid-to-High-
Pile Carpets
2-4cm
Thresholds
Side Brush
Lifted
Main Brush
Lifted
Mops
Lifted
Mop
Detached
Chassis
Lifted
Side Brush
Lifted
Main Brush
Lifted
Mops
Lifted
Quick
Mapping
Mop
Detached
Vacuum-
Only
Mop Only
Carpet
Cleaning
Mid-to-High-
Pile Carpets
Crossing
Thresholds
2-4cm
Thresholds
Returning
to Dock
Mop Drying
DirTect Technology
Adapts to
Every Mess
Adapts to
Every Mess
Dirt doesn't stand a chance with our adaptive cleaning strategy designed for various messes. When faced with heavy dust, it increases suction power, and for liquids, it seamlessly switches to mop-only mode, lifting both the side brush and main brush. No mess is too challenging to conquer.
Multifunctional Dock 4.0
10-in-1
Hands-Free
Maintenance
This is image
Auto Mop
Removal
This is image
2.5-Hour Fast
Charging &
Off-Peak Charging
This is image
80℃ Hot Water
Mop Washing
This is image
80℃ Hot Water
Dock Self-Cleaning
This is image
Intelligent Dirt
Detection for
Re-Wash & Re-Mop
This is image
Auto Detergent
Dispenser
This is image
Warm Water
Auto-Refilling
This is image
Auto Dust
Emptying
This is image
55℃ Warm
Air Drying
This is image
Detachable
Self-Cleaning Modules
Auto Mop Removal
Boost your cleaning experience with the auto-detachable mops. The Saros 10R removes its mops before initiating vacuum-only tasks and carpet cleaning, preventing any unwanted dampness.
When Vacuum-Only
When Vacuum Carpet First
*The auto mop removal needs to be activated on the Roborock App.
roborock australia auto mop removal
Saros 10R
Saros 10R
2.5-Hour Fast Charging
Saves your time with 2.5-hour fast charging, now over 40% faster than before.13
80℃ Hot Water
Mop Washing14
Stubborn grease dissolves easily from the mop, making it perfect for kitchens and dining areas.
80℃ Hot Water
Dock Self-Cleaning14
The dock stays hygienic with up to 80℃ hot water and the self-cleaning module, eliminating manual maintenance.
Intelligent Dirt
Detection for Re-wash & Re-mop
During mop washing, the system monitors dirt levels to adjust wash duration and trigger an extra mopping pass for a thorough clean.
Auto Detergent
Dispenser
The detergent is dispensed automatically, so you don’t need to fill in the detergent every time and worry about the proportion.
Warm Water
Auto-Refilling
Fills the water tank with warm water automatically when needed.
Auto Dust
Emptying
Allows for up to 70 days without manual emptying.16
55℃ Warm
Air Drying17
Dries the mops and dock base completely with 55℃ of warm air, preventing the growth of mold and unpleasant odors.
Detachable Self-Cleaning
Modules
All self-cleaning module accessories and the dock base itself are fully detachable for easy washing when needed.
80℃ Hot Water
Mop Washing14
99.99% Bacteria Removal Rate15
roborock saros 10r hot water mop washing
80℃ Hot Water
roborock saros 10r hot water dock self-cleaning
Intelligent Dirt
roborock saros 10r dirt detection
Auto Detergent
Dispenser
590ml Capacity
roborock saros 10r auto detergent dispenser
Warm Water
Auto-Refilling
roborock saros 10r warm water auto-refilling
Auto Dust
Emptying
roborock saros 10r auto dust emptying
55℃ Warm
Air Drying17
roborock saros 10r warm air drying
Modules
roborock saros 10r detachable self-cleaning modules
Say “Hello Rocky” for Help
roborock australia saros 10r built-in intelligent voice assistant
This is icon
Start and Pause Cleaning
This is icon
Cleanups by Call
This is icon
Specify Room Cleaning
This is icon
Adjust Cleaning Modes
This is icon
This is icon
Mop Washing and Drying
Easy-to-Use App
Tap. Tap. Clean.
roborock app
Roborock SmartPlan 2.0
One Tap to AI-Driven Cleaning
One Tap to
AI-Driven Cleaning
Enjoy automated cleaning with Roborock's SmartPlan mode. Just tap the app, and the robot will identify your environment and utilize AI to optimize cleaning strategies.
Saros 10R
automated cleaning with roborock smartplan 2.0
Saros 10R
Automatically deep cleans rooms that have not been cleaned for a long time.
Lowers power and reduces noise during Do-Not-Disturb periods.
Re-washes the mops right after cleaning kitchens and bathrooms or after a second mopping pass.
Mixed Pattern Cleaning
Shift for a
Superior Clean
For next-level thoroughness, the robot automatically shifts its movement to a direction perpendicular to the previous cleaning task, ensuring enhanced cleaning performance.
roborock mixed pattern cleaning
Pet-Friendly Intelligence
Saros 10R Paw-some Sidekick for Pets Paw-some
Sidekick for Pets
Video Call & Cruise
Whether you need to check in on your furry friends, schedule on-demand cruises, or manually control the robot’s patrols, it’s all just a tap away.
Pet and Pet Area Recognition
It stops its main brush and moves aside in advance when approaching your beloved pets to avoid frightening them. And it will boost suction when cleaning around pet supplies for a thorough clean.18
roborock saros 10r pet and pet area recognition
Search for the Pet
Can’t find your pet playing hide and seek? Worried about your pet being home alone? With a simple button on the App, it will roam around your home and help you find your pet.
roborock pet-friendly intelligence
Pet Snaps
Captures adorable snapshots of your furry friends during cleanups, readily available for you to download.
pet snaps with roborock vacumm
Elevate Smart Living with
Matter Protocol
Elevate Smart
Living with
Matter Protocol
Embrace the power of Matter standard through the Saros 10R, leading you to boundless smart home possibilities. Say goodbye to the frustrations of limited compatibility as you effortlessly take control of your robot vacuum and other compatible devices. Discover the true convenience of a fully integrated smart home.
Saros 10R
Broadly Compatible with
Broadly
Compatible with
roborock compatible with third-party voice control
Third-Party Voice Control
roborock compatible with launcher widgets
Launcher Widgets
roborock compatible with apple watch app
Apple Watch App
  • Scratchsafe™ Wheels and Brush
  • Sensient® Sensor Array
  • Adaptive Route Algorithms
  • Quiet Mopping (≤55dB19)
  • Child Lock
Saros 10R
350*353*79.8 mm
381*475*488 mm
roborock australia saros 10r robot and dock dimensions
STAY TUNED!
Saros 10R Saros 10R
1. As of January 2025, the Saros 10R is the thinnest model among Roborock's vacuum robots.
2. Roborock was the first in the robot vacuum industry to implement 3D ToF functionality using a dual-transmitter approach, as the technology officially launched earlier in 2024.
3. Based on internal testing carried out by the manufacturer according to the LDS sampling frequency calculation method.
4. Based on internal testing carried out by the manufacturer, Saros 10R can see and bypass objects as small as 2cm wide and 2cm tall. Recognition accuracy may vary depending on environmental factors.
5. Certified No.PT/24/GEN/0453 by SGS. Actual results may vary according to the home environment.
6. Certified No.PT/24/GEN/0454 by SGS. Actual results may vary according to the home environment.
7. Certified No.PT/24/GEN/0455 by SGS. Actual results may vary according to the home environment.
8. Certified by TÜV Rheinland. Test report number: No. 0217010051. Actual coverage depends on the environment.
11. Based on internal testing carried out by the manufacturer, the mop modules can be lifted up to 22mm away from the ground when the chassis is lifted.
12. Based on internal testing carried out by the manufacturer, the chassis can be lifted up to 10mm. Actual results may vary according to the home environment.
13. Compared to the Roborock S7. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
14. Based on internal testing carried out by the manufacturer, the water at the clean water dispensers of the dock can be heated up to 80℃ under standard room temperature. The actual temperature will vary due to environmental factors.
15. Based on testing conducted by TÜV Rheinland on Staphylococcus aureus and Escherichia coli under default mode, over 99.99% of bacteria are effectively removed at the dock. Test Report number: 0000087338. The actual results may vary according to the home environment.
17. Based on internal testing carried out by the manufacturer, the air temperature around the air outlet can be heated up to 55℃ during drying under 25℃ room temperature. The actual results may vary according to the home environment.
18. To boost suction power around pet supplies, please activate the “Pet Supply Deep Cleaning” on the App.
