" Welcome to Roborock CES 2026 | Roborock Australia
Booth #52632, Venetian Expo, Halls A–D, Las Vegas, NV
Roborock Schedule
Activity
Time
Site
New Product Launch Keynote
06/01/2026 14:00 (UTC-8)
Las Vegas, NV
ShowStoppers
06/01/2026 18:00 - 21:00 (UTC-8)
Grand Ballroom, Bellagio Hotel & Casino,
Las Vegas, NV
Roborock CES Booth Display
06/01/2026 - 09/01/2026
Las Vegas, NV
Map
Newly Launched
Robot Vacuums
Wet Dry Vacuums
Cordless Vacuum Cleaners
Lawn Mowers
Roborock-ces-Real-Madrid-CF
Saros 20
· AdaptiLift™ Chassis 3.0: Up to 4.5cm + 4cm¹ Threshold Crossing
· StarSight™ Autonomous System 2.0: Precise Navigation and Obstacle Recognition
· 35,000 Pa HyperForce® Motor² & Dual Anti-Tangle System
Qrevo Curv 2 Flow
· SpiraFlow™ Real-Time Self-Cleaning Mop
· 2.5X Boosted Mopping Pressure³
· Innovative Roller Shield
Saros Z70
· OmniGrip Mechanical Arm
· 22,000 Pa HyperForce® Suction⁴
· AI-Powered Customization
*Product availability is subjected to regional differences.
1. This product is tested to cross thresholds up to 8.5cm, including a 4.5cm threshold plus an additional 4cm track on top for double-layer thresholds, or up to 4.5cm for single-layer threshoblds. Actual results may vary depending on environmental factors.
2.Based on internal testing of the digital motor under specific conditions. Actual results may vary depending on product configuration and usage conditions.
3. Compared to the Roborock Qrevo Curv with mopping pressure up to 6N. The current model delivers mopping pressure up to 15N, based on internal testing conducted by the manufacturer. Actual performance may vary depending on home environments.
4. Based on internal testing carried out by the manufacturer. Actual results mayvary depending on environmental factors.
Roborock F25 Ultra
· VaporFlow™: Engineered for Stubborn Messes & Hygienic Cleaning
· WaveFlow™: Built for Greasy Buildup
· Elevated 22,000 Pa Suction Power¹
Roborock F25 ACE Pro
· JetFoaming Cleaning: 167 million³ ultra-dense bubbles dissolve stains and odors²
· JawScrapers Anti-Tangle Structure
· 25,000 Pa Suction Power¹
· 35% Larger, 1,000ml Clean Water Tank⁴
2. Based on internal testing carried out by the manufacturer. Stains refer to common household messes such as grease, sauces, coffee. Odors refer to Ammonia,Trimethylamine, and Hydrogen Sulfide.
4. Compared with the Roborock F25 ACE, which is equipped with a 740 ml water tank.
Roborock H60 Hub Ultra
· All-in-One Auto-Empty Dock
· Up to 210AW¹ Suction Power
· Long-Lasting Detachable Battery
1. Available on Roborock H60 Hub Ultra. Tested by TÜV Rheinland based on the IEC 62885-4:2020/5.8 standard. Tested without any accessories, in MAX mode with a full battery, and using testing equipment with a diameter of 10 mm. Actual results may vary depending on usage conditions.
RockMow X1 LiDAR
· Sentisphere™ LiDAR Environmental Perception
· Four-Wheel Drive (4WD)
· Patented Active Steering System
RockMow X1
· Sentisphere™ Environmental Perception
RockNeo Q1
· AI-Powered Smart Mapping
· Industry’s Closest-to-Edge Cutting¹
1. Based on external sources and Roborock research, the PreciEdge™ cutting module achieves a 1.2 in (3 cm) distance to the edge, making it the industry’s closest-to-edge automated trimming solution compared with products available on the market by December 2025.
Moments
Follow Us
Contact Us
Marketing
Press inquiries
info.au@roborock.com
Influencer collaboration
collab.au@roborock.com
Distribution
sales@roborock.com
