StarSight™ Autonomous System
What is the StarSight™ Autonomous System?
Roborock's StarSight™ Autonomous System leverages industry-first dual-transmitter solid-state LiDAR with 3D Time-of-Flight (ToF) technology to deliver unrivaled navigation.1 Imagine a world where your robot vacuum can see its surroundings in 3D detail, and seamlessly navigate around and under furniture. That's the power of this autonomous system.
Equipped with 21,600 sensor points* for 3D scanning and a sampling frequency 21 times higher than LDS2, it delivers precise localization, comprehensive mapping, and reliable obstacle recognition—all in an impressively compact design. This innovation paves the way for future upgrades and enhanced functionalities, setting a new benchmark for robot vacuum performance.
*The robots equipped with 3D ToF Navigation System use a QVGA ToF sensor with 21,600 sensor points.
Milestone in Navigation Technologies
Before LiDAR Navigation
Random Collision for Navigation
Gyroscope Navigation
Visual Simultaneous Localization and Mapping (VSLAM)
PreciSense® LiDAR Navigation System
In September 2016, Roborock achieved an early industry breakthrough by mass-producing its LDS-based LiDAR navigation system, improving precision in robot vacuum location and mapping.
In March 2024, Roborock unveiled the industry's first dual-transmitter solid-state LiDAR, leveraging 3D scanning technology to achieve unparalleled precision and pave the way for future innovations.
The Enhanced StarSight™ Autonomous System 2.0
With cutting-edge VertiBeam™ Lateral Obstacle Avoidance technology, the robot effortlessly maneuvers around irregular furniture and walls, delivering a seamless cleaning experience even in the presence of cables.
Unfolded Cables
Irregular Walls and Furniture
Advantages of the StarSight™ Autonomous System
Enables a Compact Design for Increased Cleaning Coverage
3D Sensing for Precise Mapping Even in Tricky Areas
Suspended Cabinets
Thin-legged Furniture
Under Furniture
Smooth Cleaning with Improved Obstacle Recognition
Small Items*
Unexpected Obstacles
Up to 301 Types of Objects Recognizable.
*Based on internal testing carried out by the manufacturer, the robot vacuum can see and bypass objects down to as small as 2cm wide and 2cm tall. Recognition accuracy may vary depending on environmental factors.
What the Experts Say
"Add in the new Time of Flight navigation, which sees the LiDAR dome removed so that the robot can get under more bits of furniture, and the powerful app and this is just about the most flexible robot that I’ve reviewed."
Trusted Reviews
"It will actually be able to SEE that there’s a clump of wires on the floor, it will clean AROUND them, getting as close as it can without getting tangled IN them, and it will even mark them on its MAP of the room so that YOU CAN see the bits YOU need to pick up. And it DOES all this, while ALSO being one of the slimmest robots on the market so it fits under basically anything."
Mrwhosetheboss
"It's even slimmer than some vacuum roller heads, an impressive feat that once felt impossible for robovacs."
TechRadar
1.Roborock was the first in the robot vacuum industry to implement 3D ToF functionality using a dual-transmitter approach, as the technology officially launched earlier in 2024.
2.Based on internal testing carried out by the manufacturer using the LDS sampling frequency calculation method.
