With a detachable power unit compatible with both bodies and two interchangeable brush heads, your machine seamlessly transforms into a wet-and-dry vacuum, or a cordless stick vacuum.
>99.99%
Bacteria Removal Rate²
Mops away both wet and dry waste.
Captures 99.99% of particles with whole-machine filtration.³
Designed for furniture gaps and window edges.
Suctioning dust from high household spaces with an extension wand.
Spend less time cleaning and more time living. With 25,000 Pa suction⁴ and a 450 RPM⁵ cleaning frequency, the Roborock F25 Lite Combo delivers spotless results in one glide.
>99.99%
20 N⁶
Downward Cleaning Pressure
450 RPM⁵
Cleaning Strokes/min
25,000 Pa⁴
Suction Power
With a 60-minute⁷ battery life under Eco Mode, it ensures uninterrupted cleaning sessions, covering up to 460 sqm (4,951 sqft) ⁸ before needing a recharge.
60 min
Battery Life on a Single Charge⁷
Up to 460 sqm (4,951 sqft)
Cleaning Area per Charge⁸
JawScrapers® Anti-Tangle Design
Conquer hair and debris with JawScrapers® design. Shark-tooth structure strip away tangles for an uninterrupted, smooth clean.
Tangle Rate⁹
Dust tends to accumulate along walls and corners. Achieves 0mm¹⁰ edge-to-edge cleaning, helping clean along walls and corners.
The body tilts smoothly to a full 180°, maintaining suction even when completely flat. At just 12.5 cm (4.9 in) high¹¹, it glides easily under furniture such as beds and couches / sofas.
12.5 cm
Body Height
180°
Lay Flat
Powerful suction paired with a unique adaptive brush, deep cleans floors and carpets, leaving them spotless and refreshed.
120,000 RPM¹²
High-Speed Motor
25,000 Pa⁴/ 130 AW¹³
Suction Power
9-Cone Cyclonic Technology
The 9-cone cyclonic system generates powerful centrifugal force to separate dust from the airflow before it reaches the filter, helping reduce clogging and maintain strong suction over time.
Filter Rate¹⁴
5-layer Noise Reduction System
≤73dB(A)¹⁵
In Eco Mode
hair tangle rate¹⁶ with unique adaptive brush
*Results may vary depending on the surface being cleaned.
One-click dustbin release for convenient dust disposal and thorough interior cleaning.
Unlock unparalleled cleanliness with intelligent high-temperature self-washing and drying. The omni-sealed dock optimizes drying, while smart technology anticipates the self-cleaning needs of your Roborock F25 Lite Combo. Advanced solid-liquid-air separation technology helps deliver a thorough clean every time.
95 ℃
High-Temperature Self-Washing¹⁷
and Hot-Air Drying¹⁸
5 min
Fast Drying¹⁹
>99.99%²⁰
Engineered to deliver fluid motion in every move, Optimized Glide Wheels reduce push effort, move smooth over floor seams, and cross thresholds effortlessly—transforming cleaning into a seamless, continuous flow.
Enhanced with a low water tank and 70° swivel design²¹, it glides effortlessly around furniture and obstacles, delivering a smoother, more efficient clean.
Receive timely notifications and updates via voice alerts, keeping you informed without checking the device.
Easily monitor device performance and settings via a clear display, with key status information available at a glance.
Key Specs
263 ×242 ×1104 mm
316 × 350 × 1163 mm
1. Based on internal testing conducted by the manufacturer using common household stains such as coffee stains, ketchup, mustard. Actual performance may vary depending on environmental conditions.
2. Based on testing carried out by TÜV SÜD on Staphylococcus aureus, Candida albicans and Escherichia coli under strong (MAX) mode, over 99.99 % of bacteria on the floor are effectively removed. Report No.: 704012409452-02. Actual results may vary according to the home environment.
3. Based on testing carried out by third-party Laboratory, In high mode, whole-machine filtration efficiency reached 99.99% for particles sized 0.30–10.0 μm. Report No.: 0363-26A-02A. Actual performance may vary depending on usage conditions and maintenance.
4. Based on internal testing conducted by the manufacturer. Actual performance may vary depending on environmental conditions.
5. Based on internal testing conducted by the manufacturer. Actual performance may vary depending on environmental conditions.
6. Based on internal testing conducted by the manufacturer. Actual performance may vary depending on environmental conditions.
7. Based on internal testing conducted by the manufacturer in Eco mode on a fully charged.
8. Based on internal testing conducted by the manufacturer, operating the machine in Eco mode with minimum suction power at a speed of 0.5 m/s. Actual results may vary depending on the home environment, level of cleanliness, cleaning habits, and other factors.
9. Based on SGS testing, the hair tangling rate is 0% when operating with 2,000 strands of 50 cm dry and wet hair across all four operating modes under controlled testing conditions. Report No.: SHES241002115876. Actual performance may vary depending on environmental conditions.
10. Based on internal testing conducted by the manufacturer. Edge cleaning performance applies to both left and right sides. Actual results may vary depending on environmental conditions.
12. Based on third-party laboratory testing. Actual results may vary depending on environmental factors.
13. Based on internal testing carried out by the manufacturer. The maximum suction reaches up to 130 AW, which generates a suction power up to 25,000 Pa. Actual results may vary depending on environmental factors.
14. Based on testing conducted by a third-party laboratory, on new filter samples in accordance with EN ISO 29463-5:2022. The test used KCl aerosol at a rated airflow of 43 m³/h and particle size ≥0.30 μm.
15. Based on internal testing conducted by the manufacturer. Actual results may vary depending on the home environment.
16. Based on testing carried out by TÜV SÜD, the average hair removal rate reaches 100.00% and left 0 hair entanglement on the brush surface. Report No.: 704012409503-03. Actual results may vary according to the home environment.
17. Based on internal testing conducted by the manufacturer. The stated 95°C refers to the temperature within the air duct, not the temperature of the water. Actual performance may vary depending on environmental conditions.
18. Based on internal testing conducted by the manufacturer. The stated 95°C refers to the temperature within the air duct. Actual results may vary depending on environmental factors.
19. Based on internal testing conducted by the manufacturer. Actual results may vary depending on environmental factors.
20. Based on TÜV SÜD testing of Staphylococcus aureus, Candida albicans, Klebsiella pneumoniae, and Escherichia coli under self-cleaning and drying mode, over 99.99% of bacteria were effectively eliminated. Report No.: 704012409452-02. Actual performance may vary depending on environmental conditions.
21. Based on internal testing conducted by the manufacturer. 70° steering refers to the combined rotation of both brush heads, each rotating at least 35°. Actual performance may vary depending on environmental conditions.
