Roborock F25 RT Gen 2
Smart, Smooth, Stainless
Find the Right Model for You
Reliably Clean,
Designed to be Easy
Outstanding Cleaning Power
One‑Stroke Deep Clean, Reliably Delivered. Combining 450 RPM3 cleaning frequency and 20,000 Pa suction4 for a thoroughly clean floor—with no effort from you.
20,000 Pa
Suction Power4
20 N
Downward Cleaning Pressure5
Bacteria Removal Rate6
450 RPM
Cleaning Strokes / min3
<1 mm Edge-to-Edge Cleaning7
Enjoy uninterrupted operation. With <1 mm edge cleaning7, a 38-minute8 Eco Mode runtime, and 284 sqm (3,056 sqft)9 of coverage, it cleans every inch of your floor deeply and continuously.
38-Minute
Battery Life in Eco Mode8
Cleaning Area per Charge9
JawScrapers® Anti-Tangle Design
Engineered for Continuous Performance
Ensure consistently spotless floors with our advanced anti-tangle system—featuring a constant-press scraper that eliminates watermarks and shark-tooth blades that actively trap hair, delivering a smooth, pristine finish with every clean.
Tangle Rate10
In Sync with Your Motion
Optimized Glide Wheels
Fluid Motion, Engineered In
Engineered to deliver fluid motion in every move, Optimized Glide Wheels reduce push effort, smooth over floor seams, and clear thresholds effortlessly—transforming cleaning into a seamless, continuous flow.
Effortless Glide
Feel the ease in every push.
Stable Roll
Safe passage for your home and machine.
Enhanced Obstacle Clearance
Glide over thresholds effortlessly.
70° Swivel Design11
Stable Base, Agile Moves
With its low‑center design, it glides steadily and maneuvers effortlessly around furniture, thanks to the responsive 70° swivel steering.
The Uninterrupted Clean
Clears the way, then reaches in. The 12.5 cm (4.9 in)12 flat design maintains full suction even at 180°, powering under furniture to leave no dust behind.
Smart-Care Simplicity
Intelligent Washing,
Advanced Purification
90°C/194°F13 high temperature self-washing delivers deep self-cleanliness, followed by advanced solid-liquid-air separation for a thoroughly purified result.
90°C/194°F
High Temperature Self-Washing13
≥99.99%
Bacteria Removal Rate14
Multiple Stages
Separation System
Flexible Drying to Fit Your Routine
Stay fresh and dry with 90°C/194°F15 Hot-Air Self-Drying in an omni-sealed dock.
Maintenance, Simplified
Ergonomic Tank Handle
Effortless, splash-free handling. The contoured grip is designed for comfortable control and secure lifting during tank removal.
1. Data sourced from SGS and Roborock's internal testing. The hair tangling rate is 0% when operating with 2,000 strands of 50 cm dry and wet long hair across all four operation modes under controlled testing conditions. Report number: SHES241002115874. Actual performance may vary depending on environmental conditions.
2. Based on internal testing carried out by the manufacturer, the stated streak-free refers to residual water streaks of less than 0.2g. Actual results may vary due to usage and environmental conditions.
3. Based on internal testing carried out by the manufacturer, using MAX mode with a full battery. Actual results may vary due to usage and environmental conditions.
4. Based on internal testing by the manufacturer with a full battery acceording to IEC 62885-2 standards. Actual results may vary due to usage and environmental conditions.
6. Based on testing carried out by TÜV SÜD on Staphylococcus aureus, Candida albicans and Escherichia coli under default cleaning mode, over 99.99% of bacteria on the floor are effectively removed. Report number: No. Z2GCN 118006 0095 Rev.04. Actual results may vary according to the home environment.
7. Based on internal testing carried out by the manufacturer. The stated edge-to-edge coverage refers to the left and right sides of the roller. Actual results may vary due to usage and environmental conditions.
8. Based on internal testing carried out by the manufacturer, using ECO mode with a full battery. Actual results may vary due to usage and environmental conditions.
9. Based on internal testing carried out by the manufacturer, using ECO mode with a full battery. Actual results may vary due to usage and environmental conditions.
10. Data sourced from SGS and Roborock's internal testing. The hair tangling rate is 0% when operating with 2,000 strands of 50 cm dry and wet long hair across all four operation modes under controlled testing conditions. Report number: SHES241002115874. Actual performance may vary depending on environmental conditions.
11. Based on internal testing carried out by the manufacturer. 70° steering refers to the combined rotation of both brush heads, each turning at least 35°. Actual results may vary due to usage and environmental conditions.
12. Based on internal testing carried out by the manufacturer. Actual results may vary due to usage and environmental conditions.
13. Based on internal testing by the manufacturer. The self-washing temperature refers to the temperature of the hot air outlet blowing over the water, not the temperature of the water itself. Actual results may vary due to usage and environmental conditions.
14. Based on testing carried out by TUV SÜD on Staphylococcus aureus, Candida albicans and Escherichia coli under default self-cleaning mode, over 99.99% of bacteria on the roller are effectively removed. Report number: No. Z2GCN 118006 0095 Rev.04. Actual results may vary according to the home environment.
