Introducing Roborock adaptive HyperScrub scrubbing technology, engineered for demanding messes. Hold the trigger to activate Scrubbing Mode and dynamically boost water delivery, suction power, and roller speed.
Built to break down stuck-on messes, dried spills, and heavy kitchen grubby², deep cleaning power activates exactly when you need it most.
245%
Increased Water Delivery³
24%
Higher Scrubbing Density⁴
36%
Enhanced Suction Performance⁵
Certified by TÜV SÜD: In a 60-minute test on solid wood flooring with deep scrubbing activated, the surface showed no swelling, warping, or cracking—delivering powerful cleaning with complete floor safety.
Spend less time cleaning and more time living. With 25,000 Pa suction⁷ and a 550 RPM⁸ cleaning frequency, the Roborock F25 Pro Turbo delivers spotless results in one glide.
>99.99%⁹
Bacteria Removal Rate
20 N¹⁰
Downward Cleaning Pressure
550 RPM⁸
Cleaning Strokes/min
25,000 Pa⁷
Suction Power
With a 60-minute battery life under ECO Mode, it ensures uninterrupted cleaning sessions, covering up to 460 sqm (4,951 sqft)¹² before needing a recharge.
60 min
Battery Life on a Single Charge¹¹
Up to 460 sqm (4,951 sqft)
Cleaning Area per Charge¹²
JawScrapers® Anti-Tangle Design
Conquer hair and debris with JawScrapers® design. Shark-tooth blades strip away tangles for an uninterrupted, flawless clean.
Tangle Rate¹³
Dust tends to accumulate along walls and corners. Achieves 0mm¹ edge-to-edge cleaning, helping clean along walls and corners.
The body tilts smoothly to a full 180°, maintaining suction even when completely flat. At just 12.5 cm (4.9 in) high¹⁴, it glides easily under furniture such as beds and couches / sofas.
12.5 cm
Body Height
180°
Lay Flat
Auto Detergent Dispenser
Enjoy up to 30 days¹⁵ of cleaning with a single detergent refill, as the auto dispenser precisely releases detergent as needed. *
Powered by dual brushless motors with independent wheel control, SlideTech 2.0 delivers ultra-smooth maneuverability with millisecond response times, enabling precise tight turns whether pushing or pulling.
Enhanced with a low water tank and 70° swivel design¹⁶, it glides effortlessly around furniture and obstacles, delivering a smoother, more efficient clean.
Unlock unparalleled cleanliness with intelligent high-temperature self-washing and drying. The omni-sealed dock optimizes drying, while smart technology anticipates the self-cleaning needs of your Roborock F25 Pro Turbo. Advanced solid-liquid-air separation technology help deliver a thorough clean every time.
95 ℃
High-Temperature Self-Washing¹⁷
and Hot-Air Drying¹⁸
5 min
Fast Drying¹⁹
>99.99%²⁰
Featuring a detachable wet-and-dry separation module, the dirty water tank keeps solids and liquids apart for cleaner, easier disposal. No more clogging, dripping, or messy cleanups.
Receive timely notifications and updates via voice alerts, keeping you informed without checking the device.
Easily monitor device performance and settings via a clear display, with key status information available at a glance.
Easily tailor settings and preferences through app customization, creating a personalized cleaning experience.
Key Specs
263 ×242 ×1104 mm
316 × 350 × 1163 mm
1. Based on internal testing conducted by the manufacturer. Edge cleaning performance applies to both left and right sides. Actual results may vary depending on environmental conditions.
2. Based on internal testing conducted by the manufacturer using common household stains such as coffee stains, ketchup, mustard. Actual performance may vary depending on environmental conditions.
3. Based on internal testing conducted by the manufacturer, compared the average water delivery in Auto Mode. Actual results may vary due to the usage and environment conditions.
4. Based on internal testing conducted by the manufacturer, compared with roller speed in Auto Mode. Actual results may vary depending on usage and environmental conditions.
5. Based on internal testing conducted by the manufacturer, compared with suction performance in Auto Mode. Actual results may vary depending on usage and environmental conditions.
6. Based on TÜV SÜD testing, after 60 minutes of on-tap scrub mode operation with push-and-pull movement on a solid wood floor, no blistering, bulging, or deformation occurred. Additionally, no visible scratches or color changes were detected. Report No.: 704012604029-00. Actual performance may vary depending on environmental conditions.
7. Based on internal testing conducted by the manufacturer. Actual performance may vary depending on environmental conditions.
8. Based on internal testing conducted by the manufacturer under on-tap scrub mode. Actual performance may vary depending on environmental conditions.
9. Based on testing carried out by TÜV SÜD on Staphylococcus aureus, Candida albicans and Escherichia coli under strong (max) mode, over 99.99% of bacteria on the floor are effectively removed. Report No.: 704012409452-02. Actual results may vary according to the home environment.
11. Based on internal testing conducted by the manufacturer in Eco mode on a fully charged.
12. Based on internal testing conducted by the manufacturer, operating the machine in Eco mode with minimum suction power at a speed of 0.5 m/s. Actual results may vary depending on the home environment, level of cleanliness, cleaning habits, and other factors.
13. Based on SGS testing, the hair tangling rate is 0% when operating with 2,000 strands of 50 cm dry and wet hair across all four operating modes under controlled testing conditions. Report No.: SHES241002115876. Actual performance may vary depending on environmental conditions.
14. Based on internal testing conducted by the manufacturer. Actual results may vary depending on environmental conditions.
15. Based on internal testing conducted by the manufacturer. A full cleaning solution tank provides up to 30 days of use under once-daily cleaning in a controlled test environment. Actual results may vary depending on home environment, level of cleanliness, cleaning habits, and other factors.
16. Based on internal testing by the manufacturer. 70° steering refers to the combined rotation of both brush heads, each rotating at least 35°. Actual performance may vary depending on environmental conditions.
17. Based on internal testing conducted by the manufacturer. The stated 95°C refers to the temperature within the air duct, not the temperature of the water. Actual performance may vary depending on environmental conditions.
18. Based on internal testing conducted by the manufacturer. The stated 95°C refers to the temperature within the air duct. Actual results may vary depending on environmental factors.
19. Based on internal testing conducted by the manufacturer. Actual results may vary depending on environmental factors.
20. Based on TÜV SÜD testing of Staphylococcus aureus, Candida albicans, Klebsiella pneumoniae, and Escherichia coli under self-cleaning and drying mode, over 99.99% of bacteria on the floor were effectively eliminated. Report No.: 704012409452-02. Actual performance may vary depending on environmental conditions.
